Old 03-13-2012, 12:03 AM   #8 (permalink)
jamesqf
Originally Posted by Steaming View Post
[IMG]Think I should go ahead and put in new sparkplugs as well?
Depends on whether you know if it's likely to have been serviced according to Honda's service dates. The recommended replacement interval is 105K miles IIRC, so unless you've a good idea that they've been replaced already, it'd be a good idea. As mentioned, they are indexed, and come in A, B, C, and D sizes. The proper size should be stamped on the cylinder head next to the plug hole.
It's also time to check & adjust valve clearance.
Another item to check/replace is the cabin air filter. You have to remove the glove box to get at it, but it's not hard.
The Following User Says Thank You to jamesqf For This Useful Post:
Steaming (03-13-2012)
