let me see if I get this. The hole in the cog is 10mm. The hole in the motor shaft can be drilled up to 12mm. Could you press a shaft into the cog? Could you press that whole thing into the motor shaft? maybe some combination of pressing and welding? Small screws would probably break, its hard to get any strength out of them.
