Originally Posted by Ken Fry
An experiment you can do: Run your vacuum cleaner. Put your hand over the end of the hose. The motor speeds up, meaning the the motor is working less. (You can verify this with a watt meter.)
Closing the valves lets the cylinder function as an air spring.
actually with no air the fan cavitates out.
a better experiment. run your vacuum with an amp meter on the cord.
then plug the inlet until you see 5 mm of vacuum. then read the amp meter.
