Old 03-13-2012, 11:44 AM   #10 (permalink)
KY_Canyon
BigBlue - '05 GMC Canyon Crew Cab 4x4 Z71
90 day: 22.39 mpg (US)
For hypermiling purposes engine braking is still inefficient when compared to coasting in neutral......could be better or worse than using normal brakes, but it's still a loss of kinetic energy. In a manual transmission, you can simply avoid it with use of the clutch, but for those of us with automatics it can make a huge difference. Engine braking is a safety feature, not an efficiency feature.
My 2005 Canyon Auto uses DFCO under certain conditions, and while more efficient than traditional injector on engine braking it is still much less efficient than neutral coasting. In it the DFCO is programed to kick off somewhere below 1800 RPM and the truck begins to coast (free wheel). So for me, coasting down hills at speeds above 60 or so causes the DFCO to kick on (which drives me crazy). If I'm at 58 MPH then the coasting is almost like driving a manual, but I never have to press a clutch. I'm hoping that the DFCO parameters can be adjusted with a custom PCM reprogramming. I think my MPG would improve significantly if the engine DFCO only operated above 2100 RPM or so.
