Old 03-13-2012, 02:14 PM   #5 (permalink)
dwtaylorpdx
I think the 2.8 was only made in the small 60 degree bell housing pattern,
There is a 3.2 block that replaces it in pretty much all the rigs that used the 2.8. Now its possible Pontiac did something weird, but the Fiero was intended to be a scrap bin car from the beginning, to keep its cost down. It uses parts from lots of GM cars.
The 4 cyl was the classic Iron duke...
I'd check the replacement long block part number between the Fiero and a S10 blazer... Same year.. Any standard auto parts store should be able to tell you if its the same number. (Bet its on the internet as well...)
Dave
If it has a motor its worth playing with.......
