Old 03-14-2012, 09:14 AM   #5541 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by bennelson View Post
They have a couple of DC motors that are rated for pretty high voltage. The Open Revolt will work fine with those motors, but you will have to keep the charged battery pack voltage lower than 200VDC.
You probably wouldn't want to do more than a 156V nominal battery pack. It would still run a Kostov fine, it just won't spin as fast as it would at a higher voltage.
156V nominal battery is the highest you would want to go with a 144V controller model.
The voltage spikes from switching will destroy parts rated for 200V when you use a nominal voltage over 156V.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
