Old 03-14-2012, 09:23 AM   #2 (permalink)
niky
Water injection should help prevent detonation under load, but you will have to size your nozzle properly and would have to set it to come on only under load, otherwise you would see it washing down oil from the cylinder walls.
And then there's the problem of, when you've tuned the water injection perfectly to prevent detonation and engine damage, engine damage occuring anyway when you run out of water.
