Originally Posted by larrydag
I'll give that a check tonight with my multimeter. I have a feeling we might need to condition the power anyway because I imagine different car manufacturers will vary on power.
So was there power going to the guino?
Actually, the previous night I cooked an atmega168 trying to set up a test fixture. The only way I knew it was the chip was to pop in a known good chip. I also tried to reset the chip by putting together a parallel ICSP and reloading the bootloader (old parallel cable, some resistors, and a bit of hard drive connector). Had to try several computers before finding one it worked with, and it did work with the good chip, but I couldn't get the bad chip to respond.
I have more chips en-route, now I don't need to get them pre-loaded with the bootloader anyway
