Old 03-14-2012, 02:03 PM   #7 (permalink)
shovel
FWIW, before I modified my 4.3 s10, as long as I had 1/4 tank of e10 I could top off with e85 and stay within the stock ECU's +25 fuel trim bandwidth.
On my 4.7HO jeep, fills-up from empty on E85 keep me inside +20 fuel trim on the stock ECU (trim runs at -1 to +1 when I fill from empty with E10) - but the HO engine has higher flow rate injectors.
It should be noted that the stoichiometry difference between ethanol and petrol has the natural benefit of reducing pumping losses - specifically since the fuel delivers some of the oxygen necessary for combustion, less air needs to be drawn through the engine for a given level of output. So as has been noted elsewhere, between the timing benefits of a higher octane fuel and the reduced pumping losses of a more oxygenated fuel, there have been reports of improved MPG on blends despite the lower BTU count per unit of volume.
Work From Home mod has saved more fuel than everything else put together.
The Following User Says Thank You to shovel For This Useful Post:
Ladogaboy (03-14-2012)
