Old 03-14-2012, 08:50 PM   #186 (permalink)
mikehallbackhoe
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
I may be wrong but I assumed if the alternator turned slower, it would put out less power. if that is the case, the ignition system probably doesn't use much electricity. would the alternator use much energy just charging just the ignition ? if that is the case, you might not need the larger pulley. the plus side would be you could drive as far as you want without losing spark.
