Old 03-14-2012, 07:52 PM   #6 (permalink)
oil pan 4
Originally Posted by rountreesj View Post
i assume one could basically introduce the boosted psi to the external water reservoir causing the pressure in the tank and lines to the nozzle to increase, then a boost pressure switch inline activating the solenoid to open releasing water...
All ready considered it and ruled it too much of a pita
Here is what I built to resolve the situation:
DIY Water Mist Injection system install, w/pics (MPG Boost Project) - Page 26 - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Instead of lean burn had you considered bumping the compression and running a more normal A/F ratio?
Lean burning a turbo gas engine is a sliperly slope.
