Old 03-14-2012, 11:13 PM   #14 (permalink)
niky
On a 911, braking torque cause by the front wheels shifts the center of inertia to a 50/50 weight balance during hard braking (entering a turn).
They also have the weight in the back for traction for powering out of a turn.
I'll post the simple diagram illustrating this, which I recall - once I find it.
Here is a thread on the topic:
Weight transfer vs brake bias - Page 2 - Pelican Parts Technical BBS
On the DeltaWing, the COG is so far back that even under braking, the rear tires do most of the work.
Apparently the long nose acts like a lever arm, with such a long arm pivoting around the rear tires, very little force needs to be applied to turn the front end. Similar to a 911 in steady-state cornering (that pendulum thing)... only even more extreme.
