renault megane dci
I didnot rework the compression space because longer term I have a plan to copy the Toyota prius system where the inlet cam is rotated for later closing. For that I need a higher compression ratio. I did the porting on a flow bench as can be seen on page 8 of this thread. The inlet flow graph is given. The exhaust had sufficient flow for the amount of power which I use on the scooter. So no work has been done on that.
