03-15-2012, 07:18 PM
#20 (permalink)
It is odd that *both* the stability and the aerodynamics would be better if the two (widely spaced) wheels were in the front. Then the wheelbase could be shorter because the weight shift under hard braking and hard cornering would move the Cg closer to the wide track wheels and this would be far more stable.
This is incorrect.
