Nope, sorry. A shorter wheel base would have required much wider front tires and as a result wider front end. If they reversed the configuration there wouldnt be enough traction in the back and they would be giving up all the aerodynamic benefits. Don't forget that this is a racecar which is either accelerating or braking at all times. The engineers got it right. Also this isnt a trike.
