Old 03-16-2012, 01:57 PM   #7 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
No.1 middle distillate is also known as kerosene.
Jet fuel and "winter blend" are mixes of No.1 and No.2.
I mix it in 25% in the depths of winter to prevent gelling.
No. 1 has a lower heat content and you can expect about 15% lower MPG using it.
I wouldn't run No. 1 much with an old-style Bosch or Roosa-Master injection pump, but I don't think it will hurt HEUI (pumpa dusa) or common-rail injectors. these are not as dependent on the fuel for lubrication.
No.6 residual oil will run a diesel but you have to heat it up to 600 degrees to get it to flow. Mix No. 6 resid with aggregate and you have road asphalt. But No.6 does have a lot of heating value - and outrageous sulfur.
No. 4 middle distillate has more heating value than No.1 or No.2, but I haven't seen this stuff sold since the 70s.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
