Old 03-16-2012, 02:26 PM   #5 (permalink)
some_other_dave
The brake line failure mode is fairly well known in very old cars, specifically 70s-vintage European cars with original brake lines. I'm not sure if American cars of that vintage have similar problems.
I also did a new thing in sanding some grooves out of the phenolic plastic caliper piston.
BuWHAAAA???? Plastic piston in the caliper? Doesn't the heat do Very Bad Things to the plastic?
-soD
