Old 03-17-2012, 12:53 AM   #148 (permalink)
Heihetech
Quick Switchover Does NOT Mean Dynamically Cycle by Cycle
Originally Posted by jakobnev View Post
Heihetech -
Which part of "The switchover between 2 and 4 cylinders occurs in 13 to 36 ms, depending on rpm." did you not understand?
The answer is "Quick Switchover Does NOT Mean Dynamically Cycle by Cycle".
Narrow minded, you just understand the first point, not the second and so on.
There are many requirement to run TRUE DCD Dynamically Cycle by Cycle, only
has fast switchover time is not enough. Are you trying to wear it our very soon?
to run TRUE DCD Dynamically Cycle by Cycle, you need to disable all 4 cylinders
instead of the inner 2. The deactivation should be done one by one, not 2 at
the same time. Please don't be fooled by the old technology packed in a new
product!
