Turbo Diesel mod, open turbo fully for better coasting.
My vehicle has a VNT (Variable Vane Turbo), it adjusts opening to match engine air requirements. A while ago I was doing some investigations on engine braking on steep downhill runs, my ECU opens the turbo fully at 3,000rpm, I noticed I had good braking till 3,000 rpm, then turbo would open up and it starts to run away. As the Turbo is the biggest restriction in the exhaust, I thought this may be useful for getting better economy, so I put together a temp set up where I could to either open or close Turbo fully depending on need, worked well, but as I was doing lots of other trials didn't do this consistantly. I am in the process of setting up a more permanent design with a microswitch on the throttle and some air solenoids to control the turbo actuator, this way I will be able to have either engine braking or free coast when throttle is off, most of the time the switch will be in the free coast position.
Those with a waste gate turbo may be able to open wastegate fully to coast or close it for engine braking.
