Originally Posted by yostumpy
I was considering removing the roof rack etc,but as some one on here said, ' its a work truck, if it ceases to be of use as a work truck, (because you've taken every thing useful off of it) the you might as well get something else. Well it is a work truck, and... well....
The question is, do you actually use the rack often ?
If not, it'll still do the same work, and still be the same work truck, just with less drag.
You can always put it back on if and when required.
