Paul , I'm not too sure if the error is consistent. I have my limiter set at 3500 rpm and it will kick the power off somewhere between 3500 and 3700. Good enough for gov work. If you can make it better then great. Btw when are these super cool new control boards going to be available to the masses?
My secret sepex controller project could really use one!
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
