Originally Posted by Frank Lee
I always inflate the heavy end of the vehicle higher and unless you regularly have heavy loads, the front of fwd cars is quite a bit heavier.
I'm a bit nervous to inflate higher since I've checked my tire pressure after 10 mile trips home from school and have found that psi can go as high as 40 front and 45 rear with heat and braking which makes me nervous to want to add more.
