Old 03-20-2012, 10:09 AM   #158 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Vic, did you verify the height of the fuel level in the carbs? Use some clear vinyl tubing on the bowl drain, curve it up in a U shape next to the carb, put the petcock on prime, open the bowl drain screw. Make sure this is correct before shimming the needle.
Good design is simple. Getting there isn't.
The Following User Says Thank You to beatr911 For This Useful Post:
HHOTDI (03-24-2012)
