Originally Posted by adamj12b
If anybody has ideas of what happened with the control board, I would love to hear them. Maybe I accidentally cooked it with too much hot air? I doubt it though ...
Hi Adam,
Thanks for all your hard work !!!
I don't have an answer for you about that microchip, debugging electronics can drive you crazy! You might have a solder bridge under the chip, you could try to do a quick toaster oven reflow of the whole PCB assembly. Flux around the chip and heatup the PCB, that would melt any small solder bridges. Just a long shot, might work?
A breakout board for the surface mounted micro would have make your life easier too ???
-Mark
