Old 05-29-2008, 04:40 PM   #5 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
RH77 -
Originally Posted by RH77 View Post
That's a good value vs. RR. I think you'll find the treads a fine addtion to the Sat. Plus, the 51 psi certified max PSI is an added assurance.
As for the circumference, an adjustment to the SG may be necessary -- not a big deal. I usually have mine set to the most pessimistic settings so I try harder. The displayed FE prompts additional effort if it's perceived as low. The trick is to disregard the setting and shoot for that higher goal. Hopefully, I'll have 2 record tanks through this and lower cruise speed.
Let us know how the new tires work out!
RH77
Thanks for reminding me. I have adjusted the SG to show a +2% speed increase on the MPH, so it is accurate for these tires.
I will be doing a GPS adjustment in the next few weeks, so I will add the results to the thread.
CarloSW2
American Solar Energy Society
