Old 03-20-2012, 07:03 PM   #32 (permalink)
oil pan 4
To get the best MPGs you need a 2wd, OD transmission like the L460E or TH700 and 3.08 or taller gears.
Build a ram air intake like this:
11 inches of water, no more. - Diesel Place : Chevrolet and GMC Diesel Truck Forums
And convert to electric fans.
Turn up the injector pump.
Put on 31 inch tires.
The engine you get will likely be a "C-code", put a duel plane "J-code" intake manifold on.
And run at least 8 degrees of advance.
A free flowing forward of the rear axel dump exhaust too if you can. I didn't see a big mpg boost from this but it was part of my 25mpg+ setup.
