Hi Garth, I checked the float levels and adjusted them 1 mm lower than the recommended 17 mm. I found that the major problem was that I mistakenly installed the needle spring clips on top of the springs rather than on the bottom. It runs much better now with a flat spot between 4K to 5k rpms that is most noticeable in the higher gears. We'll see how it goes.
