Old 03-21-2012, 01:13 AM   #1 (permalink)
mikehallbackhoe
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
another rim width question.
I researched rim width, but never found an answer. will running the same size tire on a wider rim lower the heighth of the tire. if that is the case, a wider rim should lower mpg. my crx has 4" wide rims, but one of them looks like it has been replaced. I haven't determined if it is 4", or 4.5". it is on the front. . I am thinking I should switch it to the rear until I can determine the width, or find a replacement rim. Am I worrying about nothing because of the small difference?
