Old 03-21-2012, 01:34 AM   #36 (permalink)
oil pan 4
My 6.5 has a TH700R4 which is a mechanically controlled 4L60E.
Works fine.
So no you don't have to have a 4L80E.
Most turbo 6.5L engines have the TH400 or 4L80E.
My 6.5L has a standard half ton 10 bolt rearend.
Has worked fine for well over 250 thousand miles.
An all cast iron 350 weighs about 600lb.
That 6.5L cant weigh more than 700.
The turbo and turbo manifolds would add at least another 50lb, so is 750lb with or with out the turbo?
