Old 03-21-2012, 04:21 AM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by mikehallbackhoe View Post
I researched rim width, but never found an answer. will running the same size tire on a wider rim lower the heighth of the tire.
Depends on the situation.
Ideally the sidewall is near vertical, and the tyre isn't stretched out or pinched in to fit the rim.
If I look at my own tires, 205/55R16, these may be fitted on 5.5 to 7.5 in wheels according to Tire Size Calculator - tire & wheel plus sizing so that's 5 rim widths.
Even though the fitment might be totally fine, a wide rim will angle the sidewalls out , while a narrow rim angles the sidewalls in, both giving a marginally lower sidewall height (when measured vertically).
Starting with a pinched-in situation, a wider rim might pull the sides more vertical.
