Originally Posted by moorecomp
From the law in question,
IC 9-19-12
Chapter 12. Rear View Mirrors
IC 9-19-12-1
Safety requirements
Sec. 1. A motor vehicle that is constructed or loaded so as to
obstruct the driver's view to the rear from the driver's position must
be equipped with a mirror located so as to reflect to the driver a view
of the highway for a distance of at least two hundred (200) feet to the
rear of the vehicle.
I'd say print it out and stuff it alongside your car's papers !
It's similar over here.
If you can't look out the back windows using the internal mirror, you need a side mirror on the right (these are mandatory since more than 20 years).
But even when you can't see out the back using the internal mirror, it's illegal to remove it because the car was approved thus equipped.
