Old 03-21-2012, 11:06 AM   #10 (permalink)
oil pan 4
Originally Posted by hawk2100n View Post
1/2 to 1/3 of rated output on the solar panel is about right. You are fighting physics with it mounted to the roof, seeing that the roof is slightly curved and not normal to the sun's rays. The output of the panel can be mapped as a the cosine of the angle of the panel to the sun's rays. 0 deg is head on and full output with it moving towards 0 current as you tilt it away. A lot of time the sun wouldn't get higher than 45 degrees which is .707.
That is why I use 22+ volts (panel in sun with no load) to charge a 12 volt battery.
Normally 17 to 18 volts (panel in sun with no load) are used.
