Old 03-21-2012, 04:44 PM   #4 (permalink)
shovel
I wonder if there's a rolling resistance difference between a tire that has its continuous ribs under the sidewalls like vs. one that centers a continuous rib & has blocks under the sidewall..
Clearly every pattern is different, and every compound, and even the relationships between the compound and the pattern at a given inflation amount... etc.. so everything we talk about is going to be a generalization.
Work From Home mod has saved more fuel than everything else put together.
