[QUOTE=t-max-rc - Throttle max count (pedal all the way up)
Possible values: 0-1023
t-min-rc - Throttle min count (pedal all the way down)
These adjust the throttle position limits in case you have a weird pot that doesn't close or open all the way. Mine worked with the default settings...
[/QUOTE]
I am going to use Coguar controler,
I have 1kohm-2kohm throtle -this is the oryginal throtle position from car donor so I should get around 2.5-5V , can I adjust =t-max- and min to use this throtle or I suposed to change resistor?
what values
t-max- 0t-min-rc- 1023x50%= 511 ?
Thank you for any reply.
Sebastian
