Old 03-22-2012, 02:29 PM   #86 (permalink)
Fosters80
xAviar - '06 Scion xA
Dr. Grey - '02 Ford F-150 Supercrew
Originally Posted by jncboy View Post
In particular: does it have a service disconnect switch? If it does where is it located and how does one access it? How is the IMA battery accessed?
It's behind the back seat. You have to pull the seat bottom out (1 10mm bolt I believe) and then you can unbolt the seat back. The access panels and cut off switch are all right there.
