Old 03-22-2012, 09:45 PM   #12 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Ok, now I understand what you're saying. There may be something to that. Turbodiesels tend to have much higher low-end torque than gassers. Therefore they can be geared so that you can pull a heavy load with low speed and high torque, rather than having to run the rpms up. Therefore the diesel can be more efficienct than a gasser under heavy load, but the rolling resistance is the same.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
