More details on the LCD please. What size LCD? I am going to assume its the standard 2x16. My guess is that the module uses different pins for LCD control than the MPGuino is programmed to use. Go into the code for MPGuino and change the LCD configuration to use the pins that the LCD/Keypad module uses.
