Old 03-23-2012, 11:25 PM   #37 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by pjbgravely View Post
I could have also just used my switch so I could turn on the AC in any heater position like some cars are set up.
This was the route I took.
Basically, I modified my climate control panel to add a cheapie Radio Shack microtoggle switch, then soldered two wires to the switch. One wire went to the panel's power supply, and the other wire went to the wiring connector pin that sent switched power to the engine computer to engage the fan and A/C compressor. Works like a champ.
I did this because my stock climate control panel only disabled A/C in the panel vent position. In all other positions (panel and floor vent, floor vent, defrost, A/C panel vent, and MAX A/C), the stupid thing engaged A/C.
