You wrote: "I integrated a balancing of 200mA @ 3.6V and then approx 233mA @ 4.2V (18r resistance). Balancing can be started ON/OFF by the mother board, permitting to optimize balancing algorithm if needed, and thus not just activate them when the cell reach max voltage, which is a terribly bad algorithm if the charger is not able to lower its current under the balancing current value !!"
But, I am only interested in bottom balancing the cells. That is how they get destroyed if don't have control over them. Can you configure the BMS for bottom balancing the cells?
