Old 03-25-2012, 09:01 AM   #5 (permalink)
bandit86
Buggie - '01 Vw Beetle TDI Gls
I won't remove spark plugs, the engine would still suck and blow through that hole
I removed the injector wire for every other cylinder in the firing order not just random ones.
I also disconnected the o2 sensor so the computer will not try to take readings and rich up the mixture for the 4 running cylinders.
engines are internall balanced, I dont see why vibrations would be a problem, look at harley engines they shake, ratle and roll. compressing and not firing in a cylinder still puts a load on the crankshaft
