Old 03-25-2012, 09:59 AM   #6 (permalink)
Spencer Fitch
Oh god.... You WANT the engine to suck and blow through those holes. You don't want to waste energy having your 4 cyclinders have to fight to compress the dead 4 cylinders.
I never said you removed them randomly..
You disconnected the o2 sensor obviously the computer has some type of Gaul for this I'm not sure if it would run rich or lean but it wouldnt be perfect either way. If you just left them plugged in but removed from the exhaust they would obviously make it run super rich.
Now what you really should do is remove the rods so they valves are all permanently closed and remove the spark plug so you don't compress the ccylinders hen plug your o2 sensor in and the only air that would go through the engine would be the ones that are active do your o2s would read correct and youd have best effeciency.
