Old 03-26-2012, 03:45 AM   #782 (permalink)
eimix
what version did you used?
if using obduino32K (rev198) - try commenting "#define useECUState" line 218
if using obduino32K_graphic - (rev200) had error, fixed in rev201
you have to comment "#define useECUState" too.
I see in code many comments that ELM should be tested - so it needs more tests and some debuging and fixing, good luck.
The Following User Says Thank You to eimix For This Useful Post:
Keeper (03-26-2012)
