Originally Posted by echo-francis
is it calculated like exemple there is 40km between A and B and the speed limit is 70kph you have to drive a least 60 kph to make it in time (60 is 85% of 70) and and if there are stops and lights you have to go faster besause slowing down for a stop drop your minimum average seppd of 60
Yes, it's calculated like a TSD rally where there are only elapsed time sections. If you drive at the speed limit, you have sufficient time to complete the section including stop signs, traffic lights, etc.
The navigator will know how much time you have left to complete each section, and you can adjust your speed/hypermiling to ensure that you make it to the end of section just in time. OR, in some cases, it may be advantageous to take a small time penalty to save fuel...
The instructions look like this (max 11 minutes to complete this section):
