The obvious flaw if any, is that a truck is a utility vehicle by design. Deleting the utility from the truck will defeat itsīpurpose and you will be better served with a normal car optimized for efficiency and comfort.
Having said that, a truck is the ideal mod-platform since you can do just about anything to the body without compromising structural integrity.
One idea I'm contemplating is to take out the bed and build a new aerodynamic bed from scratch. This can be much better than the add-on caps and also retain some utility.
