Old 03-26-2012, 03:44 PM   #785 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Is there any way of telling what these pins actually are? Ive got a scope I can hook up to it.
You can check that they are actually "CAN" pins by getting your multimeter out and checking what voltage you get from Pin 6 to 4/5 (ground), and PIN 14 to ground
CAN will be a balanced 2.5V line (so it'll go 2.5/2.6 on one side and 2.4 the other).
The K-Line pin could be there for either - Obsolete or for other ECUs.
An ELM327 scanner could help determine which protocol is in use.
