Old 03-26-2012, 04:18 PM   #12 (permalink)
Green Myst
Green Myst's Avatar
Thanks for asking. I've been doing work to the bike itself; mostly farkles Mostly I've been making my stock bike safer and adding storage.
Upgrades include: harder sub-frame bolts, stainless steel brake lines, pulling back the cruising seating position with highway pegs + handlebar risers + gel seat pad insert + topcase backrest. I'm also adding side cases, stronger shifter, bashplate and handguards, LED rear signals.
I plan to use the stronger bashplate and handguards to create a Vetter Alcan style fairing, and will be testing handlebar vibration to feel if I can keep off the stock bar end weights and narrow the overall profile a little bit.
I've added a fork brace and moved my front fairing much farther forward and closer to the tire to guard the rotating tire from chopping up the air in front of me. It also moves the fairing away from my radiator, which I plan to scoop the intake more when I work on the low and underside front fairing additions. I want to attach foglights to where the front fairing used to be so I can steer them but still be able to fit a window in front of them as part of the upcoming Vetter Alcan style fairing.
I got a good recommendation for some lower profile mirrors too. I plan to add some convex blindspot mirrors to them, some ultrasonic deer alert modules, gear net atop the topcase, etc.
