...most of the "older" automatic transmissions had both front & rear hydraulic "pumps" so the car could be push/bump-started. Many of the "newer" AT's now only have a "front" pump, so when the input isn't turning, there's no fluid pressure or flow.
...which type transmission do you think the Infiniti Q45 has?
