Old 03-26-2012, 08:19 PM   #56 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by echo-francis View Post
i would like to take out my p/s belt and bypass the lines but can someone give me clearly instruction on aow to do this please (my power steering have is own belt)
I did this last year on my car, which is similar to yours in that the power steering pump was run off its own belt. It's fairly simple (remove pump, belt, lines, and replace with a loop between the pressure and return lines at the rack, with an extra hose if you want a reservoir), and I followed this DIY: DIY: Removing Power Steering - Honda Civic Forum You'll need to figure out what size/thread the rack fittings are for your car before you can replace them, but the rest should be analogous.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
j12piprius (04-19-2014)
