Old 03-27-2012, 04:34 AM   #6 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Camaro, you need two input signals for MPGuino one is the vehicle speed sensor and second are pulses from a fuel injector. You've asked if you can use ABS sensor but I think it's not the best idea, because of the pulses count per revolution. MPGuino can lose some pulses and then the output will be not in correlation to reality. So the best way will be to glue one, two, maybe four magnets to the main shaft of your Camaro and put there contactron or a hall sensor. And you have constant number of pulses per mile, and that's the idea of VSS.
Second wire you have to connect to one of the injectors and then you have amount of fuel, and rpm signal for MPGuino.
That's all you need, to make your MPGuino working.
And a simple diagram for you:
1. +12V
2. VSS signal for MPGuino
3. 0V
4. Resistor ~10kohm
5. Contactron
6. Magnet
7. Main shaft
8. Diff
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
95CamaroV6 (03-27-2012)
