Old 03-27-2012, 01:29 PM   #14 (permalink)
WD40
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
An old indian (Nothing racist intended) trick to allow you to see the mark on the timing belt pulley is to use white chalk on it and rub off the excess.
The mark is cut into the pulley so rubbing off the excess leaves only the cut full of chalk. Now its bright and easy to see with the timing light.
2000 Insight MT 106K Citrus A/C
